Fibre washers - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Fibre washers (/showthread.php?tid=6422) |
Fibre washers - Hugh Barnes - 25-07-2021 Does anyone have a good source of (quality) fibre washers? I bought a selection box through Ebay some while back as they were marked as being imperial sizes. However, the range is poor (there are many of the sizes that are simply a thin 'ring' and don't work well for drain plugs etc.) But their worst fault is they are rock hard and I fear don't behave as originals would have done. Any ideas anyone? tia Hugh RE: Fibre washers - Colin Wilks - 25-07-2021 I've struggled too, then found this company. "Manufacturer of Washers, Strips, Gaskets, Seals and Sheeting" https://www.rhnuttall.co.uk Fairly pricey for small quantities, but having inherited some decent quality wad punches I went mad and bought a sheet of 2mm red fibre so I can make my own. Soaking in warm water prior to installation makes them seat and seal very nicely. I have more than I need so if you'd like some pm me. RE: Fibre washers - Hugh Barnes - 25-07-2021 That's very generous Colin, and much apreciated. Let me determine exactly the size I want (rear axle drain plug is my current concern) and I'll drop you a PM... thanks once again.. RE: Fibre washers - Ruairidh Dunford - 25-07-2021 You need this Hugh: https://www.theaustinsevenworkshop.com/products/e0121-sump-drain-plug-fibre-washer RE: Fibre washers - Hugh Barnes - 25-07-2021 You are quite right, Ruairidh, but troubling Jamie for one washer and the associated postage seems a little overkill. I was hoping that someone knew of a mixed set I could put on the shelf to cover all eventualities - and that would still be the ideal (for many of us, I suspect) but Colin's kind offer will get me out of trouble in the short term... Edit to add: Though, I do now see Jamie does a selection box which may be the way to go... https://www.theaustinsevenworkshop.com/products/gt0500-fibre-washers-assortment-9496 RE: Fibre washers - Chris KC - 25-07-2021 "Hoses Direct" sell fibre washers in imperial sizes, when I see you Hugh I can probably produce a sample or two (I need to remind myself whether they are narrow or not). You wouldn't want to order just one though, I order a few when I'm buying something else. (If stuck for something specific, give me a shout). I usually boil them in water for a minute or two before using them, softens them up a bit. |
