Starting Handle
I dismantled the starting handle cover. Seems like something is missing/incorrect.
No spring found. Can anyone explain what I have or what is missing ? It's a coil engine from 1930.
thanks
Oliver
Looks like a home made conversion from a long nose to a short nose - 'O' rings didn't exist in 1930 ?? There should be a coil spring which bears against a shoulder on the inner end of the nose and bears against the "hub" of the starting handle. I assume that the start handle boss does not pass through the bush (with the O ring) which it should do so the spring retracts the starting handle. But I could have got it all wrong !!
It should probably look like this (1929-30 pattern), with the handle shaft retained by the brass nut (the nosepiece is threaded to suit).
The later, peg type started in March 1931.
.jpg   DSC_0941ss.JPG (Size: 48.58 KB / Downloads: 206)
Hi Mopetta
http://www.austin7.org/Austin%20Seven%20...20Handles/
This is what you should have!
Well done Howard, good link. No parts available for this type, I convert them to take the later shaft as per yours on the Brookfield
Best Wishes Gene
