  • 1 Vote(s) - 3 Average
Dash screws
No doubt these nuts and screws were fitted at the factory BEFORE they fitted the fuel tank?
Yes, because the rear mounting for the petrol tank is onto the dashboard.
Parazine, do you have a source for the chrome raised counter sunk 1/4 W screws? I can only find SS.
Erich in Seattle
EKP Supplies stock 1/4" BSW x 1/2" Raised Countersunk Slotted in brass for plating yourself - note these are BSW not BSF.
https://www.ekpsupplies.com/bsw-raised-c...brass.html
I suspect they are out there if you look long & hard enough, none of the following is exactly right, just what I could find with a 10 minute search.
If resorting to buying screws then plating them I believe stainless can be chromed. (Though if polished I wonder how many could tell the difference...)
https://www.stainlessautomotivefastening...qp2nage4b0
https://www.moss-europe.co.uk/screw-1-4-...2446b.html
https://www.masonsfasteners.com/Products...CSK-Screws
https://www.rays-teksurplus.co.uk/10-x-1...5964-p.asp
(06-08-2020, 06:08 PM)Erich Wrote: Parazine, do you have a source for the chrome raised counter sunk 1/4 W screws? I can only find SS.
Erich in Seattle
I think they came from a stall at Beaulieu Autojumble about 10 years ago, so I guess the answer is no.
