05-06-2020, 09:47 PM
An old reasonable wattage bulb, even 12v is most sure test. Should get very bright as revs increase.
The dynamo must not be run for any long period with the D and F joined but not to the battery once generating. (ie if the dynamo works it is important the cutout operates)
