Car type: Austin 7 special 1934
If it works with rotating armature on the bench and not in the car it may be there is a short in the wiring. No smoke or hot dynamo?
Looks like the cut out is not working. Had the same trouble myself until I checked the cut out.
Ken Morton --1927 Chummy
Thanks,
That's the mystery. I have tried it both ways i.e with the cutout connected and disconnected as per the bench test.
Martin Nash
May not help but have you polorised the dynamo by flashing the field coils to the polarity of the car?
Did you put your earth test wire on the dynamo direct to the battery. If you only put it to a good earth on the body or engine you should check the earth strap from engine to body and also earth strap from body to battery. Once you are certain the dynamo is earthing back to the battery do all the checks again that Adam at Armani suggested.
John Mason
Was it a digital multi-meter?
They can be flakey on this type of test. A bulb or analogue meter is better
c
Hi Martin
There is a possibility that your voltmeter if digital is being upset by ignition interference Try a moving coil (pointer) voltmeter, or even a lamp, between the bridged D+F and a scraped clean part of the dynamo casing.
Car type: ARQ Ruby July 1936
On the subject of dynamos, during the restoration of my early type Ruby I was fortunate that the dynamo On the car needed very little attention apart from a good clean and some new brushes (touching wood with both hands) she is running fine.
However a large number of various spares and odd bits came with Ruby including a couple of dynamos and starter motors in various levels of decay.
I am now thinking it would be a good idea to have the best dynamo refurbished as a spare and note Armato noted in Martin’s original post, can anyone offer any recommendations for rewinding and refurbishing a dynamo and highlight any pitfalls.
Any advice most welcome
Cheers Denis S
John and Charles
Many thanks for this. If it is the multimeter (being influenced by the ignition system) then and we can establish with a regular voltmeter or even a lamp that the dynamo is charging then the fault lies in the cut out box. I will try tomorrow. will advise.
Also will check earth straps although I think these are sound.
Martin
