01-05-2020, 06:57 PM
Hi All, Patrick (son & heir) and I have spent the day sorting the A7 boxes in the shed. All of them. This is to try and cut down my buying bits for his car, that we already own, however deeply buried they are!
This has generated a significant pile of original A7 bits, mostly pre 1930, that are damaged, worn, cracked or all of these! Broken or 'spun' halfshafts, chipped or toothless crown wheeels, broken castings inc. mag timing case and coil dynamo mounting, chipped timing gears, a camshaft with chipped oil pump drive teeth etc. I suspect this lot all needs chucking away, but can anyone think of a use, sculpture? etc
It is available free of charge to anyone who wants all or some of it, and if you make a good enough case i will even pack and ship it at my expense, but you have to have a good idea! Lock down challenge.
W
W
