Does anyone have experience of having this journal repaired by welding?
If so aside from needing the centre cam bearing line bored did the welding cause any other distortion?
Thanks
Charles
Yes and no it didn't.
In my case it was a crack and we chose to keep the ring in place whilst welding and line boring was not required.
It has been in hard service for a number of years now, over many thousands of miles. No issues.
Hi Charles, if choosing to weld with a ring in, I would turn up a ring in brass dimensionally the same as
the steel ring and use that. Unless the crankcase is special in some way probably easier to get another crankcase.
