Centre cam bearing repair - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Centre cam bearing repair (/showthread.php?tid=4223) |
Centre cam bearing repair - Charles P - 20-04-2020 Does anyone have experience of having this journal repaired by welding? If so aside from needing the centre cam bearing line bored did the welding cause any other distortion? Thanks Charles RE: Centre cam bearing repair - Ruairidh Dunford - 20-04-2020 Yes and no it didn't. In my case it was a crack and we chose to keep the ring in place whilst welding and line boring was not required. It has been in hard service for a number of years now, over many thousands of miles. No issues. RE: Centre cam bearing repair - Charles P - 20-04-2020 (20-04-2020, 05:21 PM)Ruairidh Dunford Wrote: Yes and no it didn't. Thanks - that's good to hear. I've seen quite a few crankcases with this repair so figured it's not a stopper. I just need to find a decent welder somewhere near me to tackle the problem when we emerge from our caves again. c RE: Centre cam bearing repair - Zetomagneto - 20-04-2020 Hi Charles, if choosing to weld with a ring in, I would turn up a ring in brass dimensionally the same as the steel ring and use that. Unless the crankcase is special in some way probably easier to get another crankcase. |
