15-04-2020, 03:36 PM
Hi Can anyone please tell me the year and info on engine number M256468.
Engine numbers
15-04-2020, 04:36 PM
(This post was last modified: 15-04-2020, 04:38 PM by Paul Cooper.)
According to Wyatt it around the end of October 1936
Further note, it should be a three bearing engine given the date
15-04-2020, 04:41 PM
It is probably a 3 bearing engine, from around October 1936.
If so, there should be the head of a bolt high up on the crankcase side, half way along, just below the tappet cover. It may have been modified the take a 2 bearing crank, though. I don't know if this can be checked by looking down the oil filler tube. If 3 bearing, and the engine came from, or is still in a car that hasn't run for years and years, the crank is probably broken. They will often turn over on the handle, even with a broken crank. If it has obviously been looked after, then a good three bearing engine is a much smoother driving experience. Simon
15-04-2020, 09:38 PM
Thanks guys
