Hi,
I am in need of altering the fuel level on my zenith carb as it was leaking fuel when on a hill (not good for trailing). Does any one have any tips and what should the level be
Thanks
Hi
Might help if we knew which model of Zenith?
On a 22FZ it should be 3mm below the jet level. Yes all Zenith carb measurements seem to be metric!). Not a straightforward task to accomplish and definitely one with the carb off the car.
He Hi sorry yes it’s a 22fz. How is best to measure the level.
Hi Again
If you put “updraft carb float level” in the little Search box above all will be revealed. I may have misled you in the last post the fluid level should be 1mm below the main jet.
Thanks for all the useful reply's.
I will give it a go
