Ruby part
Can anyone suggest a supplier of rear exhaust pipe.
Austin warehouse still waiting for stock.
A near Staffordshire location would be best.
Regards
            Tim
I tend to scavenge scrap piles for bits of exhaust system from which to cut tail pipes.  Some run over the axle, some below. They're usually over-bore and fit over the silencer outlet, rather than slotting into it, but work perfectly well.
Thanks Martin
I may have try that if I can’t find a supplier.
which model is it for, Tim? I may have a NOS up and over axle rear. Can photograph on Friday...
Have you tried Mark Greening at Alderton? He certainly has, or recently had,  side exit silencer/exhaust in stock. When the wriggly long tail pipe on the Ruby finally rots away or gets terminally bashed I will be putting a side exit on to replace it.
The Seven Workshop have one listed on their website.
Just curious, is this what you mean by Austin Warehouse?
Peter.
Alderton have no stock of the up and over.
Not sure about side exit it wasn’t offered.
Sorry I meant seven workshop also no stock
