Ruby part - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Ruby part (/showthread.php?tid=3129) |
Ruby part - Tiger - 23-07-2019 Can anyone suggest a supplier of rear exhaust pipe. Austin warehouse still waiting for stock. A near Staffordshire location would be best. Regards Tim RE: Ruby part - Martin Prior - 23-07-2019 I tend to scavenge scrap piles for bits of exhaust system from which to cut tail pipes. Some run over the axle, some below. They're usually over-bore and fit over the silencer outlet, rather than slotting into it, but work perfectly well. RE: Ruby part - Tiger - 23-07-2019 Thanks Martin I may have try that if I can’t find a supplier. RE: Ruby part - JonE - 24-07-2019 which model is it for, Tim? I may have a NOS up and over axle rear. Can photograph on Friday... RE: Ruby part - Steve kay - 24-07-2019 Have you tried Mark Greening at Alderton? He certainly has, or recently had, side exit silencer/exhaust in stock. When the wriggly long tail pipe on the Ruby finally rots away or gets terminally bashed I will be putting a side exit on to replace it. RE: Ruby part - Peter Naulls - 24-07-2019 The Seven Workshop have one listed on their website. Just curious, is this what you mean by Austin Warehouse? Peter. RE: Ruby part - Tiger - 24-07-2019 Alderton have no stock of the up and over. Not sure about side exit it wasn’t offered. Sorry I meant seven workshop also no stock |
