Clearly not designed to provide high compression. Could this be for a blown car?
I believe its a Brooklands head I would be interested i purchasing if it is for sale
What does the top side look like Chris ?
My first thought was Brooklands, too. Early primitive plug position rings a bell, designed more to protect plug than for optimum combustion. Later and better designs were much closer to the exhaust valve.
I had one of these many years ago - I was told it was for a supercharged car but Brooklands sounds more exciting.
Ruairidh, I believe they did use an almost identical casting on supercharged Ulsters, although probably with a lower CR, so you may well be correct.
I reckon you've nailed it John!
Just out of curiosity what is your source?
