A7 block
Hi folks
Does anyone know whether the block for a 3 bearing Ruby is the same a 2 bearing ?
Or any other block?
Regards
           Tim
The blocks differed slightly over production but are interchangeable - what are you planning specifically?
I have one cylinder which is badly damaged
So just need to find the best way to overcome this
Engine is bored out to 0.060” already
A good bock with the same bore would be really good
May have to compromise with what’s available
Regards
Tim
