A7 block - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: A7 block (/showthread.php?tid=1740) |
A7 block - Tiger - 17-09-2018 Hi folks Does anyone know whether the block for a 3 bearing Ruby is the same a 2 bearing ? Or any other block? Regards Tim RE: A7 block - Ruairidh Dunford - 17-09-2018 The blocks differed slightly over production but are interchangeable - what are you planning specifically? RE: A7 block - Tiger - 17-09-2018 I have one cylinder which is badly damaged So just need to find the best way to overcome this Engine is bored out to 0.060” already A good bock with the same bore would be really good May have to compromise with what’s available Regards Tim |
