1928/9 Bulkhead to block spacing
Good day all. Thanks to the advice on the throttle cross shaft it is now installed but very close to the block. This prompts the question what is the spacing between the depression in the bulkhead and the block/core plug?
Stuart
Not very much !
Hi Stuart,
as Bob alludes to, this can be tight and can vary from car to car. However, I would suggest that it is usually around 1/4".
