1928/9 Bulkhead to block spacing - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 1928/9 Bulkhead to block spacing (/showthread.php?tid=1321) |
1928/9 Bulkhead to block spacing - Stuart Joseph - 12-06-2018 Good day all. Thanks to the advice on the throttle cross shaft it is now installed but very close to the block. This prompts the question what is the spacing between the depression in the bulkhead and the block/core plug? Regards from the creative county - Staffordshire Stuart RE: 1928/9 Bulkhead to block spacing - bob46320 - 12-06-2018 Not very much ! RE: 1928/9 Bulkhead to block spacing - Ruairidh Dunford - 12-06-2018 Hi Stuart, as Bob alludes to, this can be tight and can vary from car to car. However, I would suggest that it is usually around 1/4". |
