Camshaft timing gear wheel
Camshaft timing wheel to replace one that has been savaged by an Accuspark Dynamotor gear.
Assuming you are after the standard 7/8 to 3/4 taper I know Ian Bancroft has a bucket load of second hand camshaft gears.
Thanks Colin , how do I contact Ian ?
Edit : Just found his web site , I will contact him on Tuesday , thank you.
Now sorted thanks.
