Camshaft timing gear wheel - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Sales & Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=9) +--- Forum: Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Camshaft timing gear wheel (/showthread.php?tid=1239) |
Camshaft timing gear wheel - Nigel was in Brittany - 26-05-2018 Camshaft timing wheel to replace one that has been savaged by an Accuspark Dynamotor gear. RE: Camshaft timing gear wheel - Colin Wilks - 27-05-2018 Assuming you are after the standard 7/8 to 3/4 taper I know Ian Bancroft has a bucket load of second hand camshaft gears. RE: Camshaft timing gear wheel - Nigel was in Brittany - 27-05-2018 Thanks Colin , how do I contact Ian ? Edit : Just found his web site , I will contact him on Tuesday , thank you. RE: Camshaft timing gear wheel - Nigel was in Brittany - 30-05-2018 Now sorted thanks. |
