14-05-2025, 08:44 AM
Sump bolt thread restoration
14-05-2025, 10:17 AM
15-05-2025, 08:53 AM
Thanks again Ruairidh.
If I do happen to use the 1.5D length, would it cause thread bind, do you think? I haven't received the V-Coil kit yet, so I can't check.
Cheers, Geoffrey
15-05-2025, 09:57 AM
You can put 1.5D in some of the holes but not all. It’s not worth the hassle. 0.5D Vcoils are cheap enough.
15-05-2025, 10:12 AM
15-05-2025, 08:44 PM
Okay, no problems. Someone in the past was very heavy handed when drilling and tapping my crankcase to 5/16". It's broken through the back of the casting. So the threads are long, and I have no idea how long the original 1/4" was, hence my questions. Thanks.
Cheers, Geoffrey
Yesterday, 07:46 AM
Indeed. For those I would suggest a dab of thread sealant. A 1/2D helicoil is more than strong enough to hold the sump on, regardless of the screw length, but won't self-seal.
