Sump bolt thread restoration - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Sump bolt thread restoration (/showthread.php?tid=9994) |
Sump bolt thread restoration - falcott - 10-05-2025 Hi all, I'm wondering if it's possible to restore the 1/4" threads in the crankcase back from the 5/16" threads that it is currently? I'm thinking of fitting an ally sump, and it will be a shame to drill it out to 5/16. Or would it be better to change the crankcase? Ta. RE: Sump bolt thread restoration - Ruairidh Dunford - 10-05-2025 Fit helicoils. RE: Sump bolt thread restoration - falcott - 11-05-2025 Do helicoils work for threads already tapped out to 5/16"? I've never used helicoils before. For example, would these work? https://nzsafetyblackwoods.co.nz/product/recoil-thread-repair-kit-bsw-1-4-20-457154 RE: Sump bolt thread restoration - Ian Williams - 11-05-2025 No they don't, if the case is already out to 5/16 or above I use bespoke brass or aluminium inserts to plug the holes if the case RE: Sump bolt thread restoration - falcott - 11-05-2025 Ah, okay. I'll look at getting some plugs made up, I guess. It could be an engine-out job. RE: Sump bolt thread restoration - bystander - 11-05-2025 How about converting to stepped studs, 5/16" down to 1/4"? That would save an engine out job. RE: Sump bolt thread restoration - falcott - 11-05-2025 (Yesterday, 07:34 AM)bystander Wrote: How about converting to stepped studs, 5/16" down to 1/4"? That would save an engine out job. Good point! I never thought of that. Thanks. RE: Sump bolt thread restoration - Ian Williams - 11-05-2025 Studs will work although they can make sump removal in-situ difficult. I would not recommend undertaking any of this work without removing the engine first. |
