  • 1 Vote(s) - 4 Average
Sump bolt thread restoration
#21
(14-05-2025, 08:42 AM)falcott Wrote: I guess that's from the top of the coil?
Yes, as you will need the tang at the bottom to wind the helicoil in.
Gotcha.
Cheers, Geoffrey
Thanks again Ruairidh.
If I do happen to use the 1.5D length, would it cause thread bind, do you think?
I haven't received the V-Coil kit yet, so I can't check.
Cheers, Geoffrey
You can put 1.5D in some of the holes but not all. It’s not worth the hassle. 0.5D Vcoils are cheap enough.
(15-05-2025, 09:57 AM)Alan Wrote: You can put 1.5D in some of the holes but not all. It’s not worth the hassle. 0.5D Vcoils are cheap enough.
What Alan said...
Okay, no problems. Someone in the past was very heavy handed when drilling and tapping my crankcase to 5/16". It's broken through the back of the casting. So the threads are long, and I have no idea how long the original 1/4" was, hence my questions. Thanks.
Cheers, Geoffrey
Quite a few sump bolt holes go through into the sump. Some are blind.
Indeed. For those I would suggest a dab of thread sealant. A 1/2D helicoil is more than strong enough to hold the sump on, regardless of the screw length, but won't self-seal.
