Hi All,
In converting my Ulster Rep from 12 volt to 6 volt, I just realized my horns(I have a Rist as well as a Klaxette) are intended for 12 volt. Will they work on 6 volt or will I need to flog them and find a proper 6 volt horn?
Erich in Mukilteo
I think it likely that using a 12 volt horn on 6volts will give poor sound if any. You are better off going the other way where the right resistor might give satisfactory performance.
Hi
Horns tend to take quite a lot of current, so any electronic converter needs to be man enough for the job
Car type: Austin 7 Ruby 1938
Hi Erich,
I have a 12 volt horn similar to the Altette horns fitted to the Rubies. This works well enough on 6 volts to satisfy local (WOF/MOT) inspectors. It was not reliable for a while until I discovered that one cell in my 6 volt battery was faulty. With a new battery it's fine. This indicates that these horns have a high current draw, reinforcing John Cornforth's comment.
Regards
Graham
