25-07-2021, 12:16 PM
Hi I need to remove the bronze bushing from the track rod arms. Is it something I can press out or do I need to go to an engineering works to also press new ones in?
![Smile Smile](https://www.austinsevenfriends.co.uk/forum/images/smilies/smile.png)
Ruby track rod bush
25-07-2021, 03:46 PM
I think they will come out using a suitable size plain punch. Fitting the new ones can be achieved by squeezing in a vice, after which they need careful reaming to size.
25-07-2021, 08:54 PM
The worn ones can be easily removed by CAREFULLY cutting through the bushes with a junior hacksaw which makes it simple to drift them out. New ones pushed in using Vice as already suggested.
27-07-2021, 02:10 PM
Thanks guys you for your advice will do as suggested
