Rear axle fill/level plugs
After welding a nut on the plug on my late style axle and using some force it gave up its tight grip and did the honourable thing and backed off. I've matched the thread to 1/4 inch BSPT and got a replacement from Colchester Hydraulics, but any plumbing merchant should have something that matches the original.
