Rear axle fill/level plugs - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Rear axle fill/level plugs (/showthread.php?tid=64) |
Rear axle fill/level plugs - Tony R - 12-08-2017 After welding a nut on the plug on my late style axle and using some force it gave up its tight grip and did the honourable thing and backed off. I've matched the thread to 1/4 inch BSPT and got a replacement from Colchester Hydraulics, but any plumbing merchant should have something that matches the original. |
