10-04-2020, 02:51 PM
Hi Ruairidh, if your asking me ? cant at present, cars in bits, as putting in new loom, and rebuilt engine, sorry.
Very early Ruby - little details/differences...
10-04-2020, 02:54 PM
That’s a pity.
10-04-2020, 04:41 PM
Ruaridh does that early Ruby have rivets like mine does? See the two photos. Mine does not have that early brakelight switch. It has a similar switch, but with a straight pull, not the lever. The petrol filler bracket is interesting. My car did have this, but on reassemble I had no idea what it was. I wasn't even sure it was off the Austin seven my car is HV4459 registered 31st December 1934 chassis 207243 car ARQ 6957
10-04-2020, 04:44 PM
I am unable to tell you the answer to that until it comes back from paint Andrew, that may be some time...
10-04-2020, 06:35 PM
...and I trust you have found a decent painter now Ruairidh! By the way the motor cycle brake light switch was used from the 30's right up to the 60's I think.
10-04-2020, 06:47 PM
I will let you know - I certainly hope so. So many are not interested in real work, just fixing a scratch or dent these days.
Thanks for your help with it all the other year!
11-04-2020, 09:25 AM
Always a pleasure!
