03-08-2021, 02:48 PM
Can someone please confirm the correct (original) bore size for 2-bearing oil jets?
I'm fairly sure they are 3/32" at the lower end but possibly restricted at the top?
(If I understood correctly 3-bearing jets are 1/16" at the top opening to 3/32" at the lower end).
Been through several old threads and my available books but not found a clear answer so far...
