Oil Jet Bore Size - Printable Version
+--- Thread: Oil Jet Bore Size (/showthread.php?tid=6464)
Oil Jet Bore Size - Chris KC - 03-08-2021
Can someone please confirm the correct (original) bore size for 2-bearing oil jets?
I'm fairly sure they are 3/32" at the lower end but possibly restricted at the top?
(If I understood correctly 3-bearing jets are 1/16" at the top opening to 3/32" at the lower end).
Been through several old threads and my available books but not found a clear answer so far...
RE: Oil Jet Bore Size - Steve Jones - 03-08-2021
Just measured 1 original and 2 repro 2 bearing jets. All 3/32" top and bottom.
RE: Oil Jet Bore Size - Chris KC - 03-08-2021
Thank you very much Steve.
