crank timing gear
I wondered if anyone had a spare +1 crank timing gear.
I have been running my sporty two bearing engine with an 1.5" phoenix crank with a high lift cam and flat followers etc  , but have decided to rebuild it without the noisy cam and so thought I might try matched gears . I had a +1/2 crank gear and +2 cam gear in the +1 marked crankcase but as I have a +1 cam gear , I thought I might try asking if anyone has an odd +1 crank gear.  Failing that I will resort to trying others from my box of parts, as previously seen advised on this forum.
Chas
I have a pair of new old stock steel gears negligible, surface corrosion.
I am not sure where they are placed in the engine!...I no longer have a parts book, but they came with a 1929 RK  & a 1932 AG
Larger (4.3/8" O/dia  I/d taper 3/4 to 7/8" with key slot) no 1A485 with 0  2 numbers stamped and two holes to reduce weight?
Smaller (2.3/8"O/dia  I/d) 1 1/8" no taper with key slot) no number except 0 then +1 1/5? stamped, but the partner tied to the larger with 90 year old string!!
Dimensions very nominal (measured with a steel rule!)
Any interest to you or anyone else?
David
