Carburetta 22FZB
Hello, Can any one help. I need info on how to set the carb up. The weights that control the float are badly worn, which does not help so these parts are needed.  Huh Any more simple or newer type that will work.
Wiilie Mckenzie at Austin 7 Reproduction Parts does spares including the weights for 22 FZ(B) carburettors at www.austinrepro.com Tel : 01202 625242
Hi
David Cochrane at A7 components sells a reproduction booklet on the Zenith carb
Thanks parts ordered.
Thanks looking in to it now.
The booklet ( or a similar version) is also on the Austin seven digital archive, top one on this page http://archive.a7ca.org/collections/show-brochures/
Hours can be lost on the archive, such a lot digitalised, what a fantastic resource, hats off to those involved.
will have a look
