Carburetta 22FZB - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Carburetta 22FZB (/showthread.php?tid=4463) |
Carburetta 22FZB - royjackson - 03-06-2020 Hello, Can any one help. I need info on how to set the carb up. The weights that control the float are badly worn, which does not help so these parts are needed. Any more simple or newer type that will work. RE: Carburetta 22FZB - Lowespeed - 03-06-2020 Wiilie Mckenzie at Austin 7 Reproduction Parts does spares including the weights for 22 FZ(B) carburettors at www.austinrepro.com Tel : 01202 625242 RE: Carburetta 22FZB - Howard Wright - 03-06-2020 Hi David Cochrane at A7 components sells a reproduction booklet on the Zenith carb Cheers Howard RE: Carburetta 22FZB - royjackson - 03-06-2020 Thanks parts ordered. Thanks looking in to it now. RE: Carburetta 22FZB - Mark R - 03-06-2020 The booklet ( or a similar version) is also on the Austin seven digital archive, top one on this page http://archive.a7ca.org/collections/show-brochures/ Hours can be lost on the archive, such a lot digitalised, what a fantastic resource, hats off to those involved. RE: Carburetta 22FZB - royjackson - 03-06-2020 will have a look |
