12-02-2020, 08:10 PM
What is the diameter of the front shackles bush and pin please?
Front shackles
12-02-2020, 09:15 PM
Hi there.
The bush (and therefore pin diameter) is 7/16". Fit the bush in the spring eye and ream to the final diameter in place. Cheers Bob
12-02-2020, 11:12 PM
Thank you Bob, I had a feeling it was 7/16 but it’s good to ask?. I have reamers ?
10-04-2020, 06:49 PM
Hello
I never had reamed such a bush. What is a appropriate play between bush and bolt?
10-04-2020, 07:21 PM
I reamed mine to move it from what would have been a tight/slight press fit to a nice smooth fit, perhaps a couple of thou, so just enough gap for smooth lubrication?
Andy B
Of course there must be a gap for lubrication. Are there concrete hints in any workshop manual?
Same problem will occur when i will change the bush and the brake cam.
10-04-2020, 09:54 PM
I replaced my front axle shackles and bushes recently. I went for a smooth push fit of the lightly oiled pin in the bush that I could press in with my little finger. A good tip I was given was to soak your reamer in paraffin if you need to take a little more material out of the bush. If the new bush is loose in the spring eye a layer of solder works well to fill the gap.
