Car type: A7 special 34
Following some strange handeling effects our special developed I have been through all of the normal stuff and found nothing until I looked at the front end. It appears the offside wheel points somewhere near correct and the drivers side points out from where I would normally expect. Most likely the result of a bump whilst trialing or one of the many large potholes in the roads round here. I was wondering what the correct toe in should be in terms of angle or measurment front to mack of the wheel.
Regards in advance
Hugh
Hi Hugh,
Somewhere between zero and 1/8" toe-in should be about right.
Thanks I will dig out the dunlop tracking jig and set to 1/8" on Thursday and try it out on the way to work on Friday
11-07-2023, 11:18 PM
(This post was last modified: 11-07-2023, 11:19 PM by Tony Press.)
Should do it- make sure the caster is correct as well. Both kingpins leaning back just a little.
