10-02-2018, 02:44 PM
(10-02-2018, 01:14 PM)Pearls not a Singer Wrote: I believe that similar operating arms were used by BMC, british Leyland, Rover et al up until the nineties. My sender has worked since 1985 with a plastic Austin Maxi float which fits perfectly into the loop on the end.
If our cherished suppliers don't have a gasket, one should be available from an Austin Healey Sprite spares supplier
Loop on the end? What luxury!
1931 RN, 1933 APD
