18-08-2022, 10:10 AM
I have used Classic Dynamo & Regulator Conversions and norbsa (http://www.norbsa02.freeuk.com/goffyleds.htm). Both entirely satisfactory.
LED units for D and Pork Pie type rear lights…
22-08-2022, 11:10 PM
Thanks Graham
I'll investigate landrover stockists
23-08-2022, 01:24 AM
(18-08-2022, 08:59 AM)Denis Sweeney Wrote: I have LED’s in all my Ruby lights, sides, headlamps, rear wing side and brake, pork pie, side indicators and flashing trafficators. All from a uk supplier, not the cheapest option but they are all very bright. I have also inadvertently left lights on overnight during the Eurotour and she started without any issue of draining the battery.Denis - might you have details of the LED boards used in the rear lights?
23-08-2022, 04:54 PM
Sent you a pm Tony
25-08-2022, 05:32 PM
Tony, further to your comments regarding LED's for rear wing lights on a Ruby I attach a photo of the LED board fitted into my rear lights which act as side and brake lights.
The original rear wings lights were in a very sorry state with rusted bezels, perished rubber and corrode bulb holder and so I purchased a pair of repro lights and fitted the LED boards as shown below using the fitting kit provided with the boards. The board act as both side and brake lights and are very bright in use. I did try to PM you with this message but could not get the message to go with the photo attached. Hope this helps
28-08-2022, 05:43 PM
(25-08-2022, 05:32 PM)Denis Sweeney Wrote: Tony, further to your comments regarding LED's for rear wing lights on a Ruby I attach a photo of the LED board fitted into my rear lights which act as side and brake lights. Thank you, David. Where did you buy them?
28-08-2022, 08:57 PM
Tony, all my LED’s were from Dynamoregulatorconversions
28-08-2022, 11:35 PM
29-08-2022, 03:58 PM
(This post was last modified: 29-08-2022, 03:59 PM by Denis Sweeney.)
Tony, attached a photo of my Ruby showing the rear side and pork pie lights in action, as you can see they are very bright, not everyone's cup of tea for sure but think they are very affective.
Cheers Sorry effective!!
29-08-2022, 05:48 PM
