cu carb
i have a 1/1/4 in carb for my austin 7 what size jets do i need cheers
You will need to provide a lot more information to obtain and answer which is relevant to your situation, if you have a standard unmodified engine the carb you have is too big and will never provide optimum performance.
(29-03-2022, 06:54 AM)Ian Williams Wrote: You will need to provide a lot more information to obtain and answer which is relevant to your situation, if you have a standard unmodified engine the carb you have is too big and will never provide optimum performance.
If your engine is moderately tuned you could start with a no.6 needle and blue spring. It may be on the rich side but it’s what I use and seems to give a good performance.
CU ? SU ?
