Guessing Total Miles
Nick is spot on.
I am currently working on an engine I first put together around 7 years ago. I spent a lot of time and effort cleaning the inside properly before it was built up. It has been used regularly since using 20/50 detergent oil which has been replaced each year - the inside is still spotless and the bearings are in first class condition.
