(01-09-2018, 04:01 PM)Colin Morgan Wrote: Hi,
How far did Sevens used to go in the old days between rebores, please?
The engine block on my Ruby is likely to be original (Feb '37) from the M number stamped on it. Given it is currently sleeved and bored to -20 thou, would this suggest that the total mileage the car has travelled is about 5 rebores x 20K = 100K miles, or maybe a bit more? The speedo currently reads 22K - perhaps this is suggesting that the total is about 120K? (That is not a lot in 81 years, though.)
Colin
Hi Colin
My erstwhile mentor (who taught me all) Les Sweet opened his garage in 1923 in Leeds and did many many Austin seven engines. He always told me that he expected them to do 60k or maybe slightly more if done correctly in fact he warranted his rebuilds for 30K !
Certainly my RP saloon (owned by me since 1968) engine had a rebuild in 1972 and did 63k before it's next one which was in 1991, since then it has had an easy life (due to not relying on it for all use) as this engine has only done 16k since.
Now, like many of you I have several cars on the road (they all get used).
To date it runs well currently, smoke free and good compression.
So with current use all being well it should last my lifetime baring the unforeseen !
As a matter of interest I choose to use SAE 30 oil (none detergent).
A fresh engine of mine gets gentle treatment of the first 1000 miles. I change the oil at 100 miles then four changes at 250 then 500 thereafter.
I also remove the sump tray for cleaning the bottom out every three changes.
Oil seems cheap maintenance to me.
Quality of boring, quality of pistons and rings and
correct fitting is paramount.
I learnt that lesson the hard way with some inferior parts I fitted some years ago.
If in doubt get expert advice would be my suggestion.
Proper cleaning of the crankcase and related parts is another essential - an area that many take short cuts with.
Above all else do not compromise, you risk doing it twice if you do.
Bearings are an area of poor performance there are some horrible cheap Chinese things not worth using.
Use RHP as original - they last.
Having good dynamic balancing is also worth doing for smoother running and longer life.
Interestingly all the new cranks I have had required balancing despite the various suppliers saying they were balanced.
Hope that is of interest.
