[attachment=2603][attachment=2603]
I've been reading through an old thread on prop shaft lengths. Three are mentioned - BP28 20" long, BP73 19.5" long and BP93 but no length given. Did the length for the BP93 ever get tied down? Looks like mine's just a bit too short!
Car type:
I think the consensus that it was the same as BP28...
Out if interest, why do you think its too short and by how much? I was wondering with mine [that is now on a late type 3 SWB axle and thus should be back to 20] whether 19.5 will be fine anyway, as presumably it jsut puts wear into a slightly different part of the carden block.
byut I'm not sure.
Hi,
I have seen a turned spacer fitted behind the carden block.
I used to have one but have not seen it for years.
I think I have a propshaft that has been cut and sleeved to change its length as well.
Anyone with a lathe and a lump of steel or aluminium should be able the make one for you.
Good Luck with your solution.
Thanks all, should have gone to spec savers, checked prop shaft yesterday and it's a short one. Already started on a spacer to fit behind the housing which I should have finish today. Cap screws on one side to screw spacer onto housing, studs out back to pick up flange. JonE - I'd go for the 20" shaft, I'll email you a picture of the housing / blocks when I fitted the short shaft. Once again, thanks all for comments.
