Short chassis prop shaft lengths? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Short chassis prop shaft lengths? (/showthread.php?tid=1140) |
Short chassis prop shaft lengths? - Scarlet O'Hara - 28-04-2018 [attachment=2603][attachment=2603] I've been reading through an old thread on prop shaft lengths. Three are mentioned - BP28 20" long, BP73 19.5" long and BP93 but no length given. Did the length for the BP93 ever get tied down? Looks like mine's just a bit too short! RE: Short chassis prop shaft lengths? - JonE - 28-04-2018 I think the consensus that it was the same as BP28... Out if interest, why do you think its too short and by how much? I was wondering with mine [that is now on a late type 3 SWB axle and thus should be back to 20] whether 19.5 will be fine anyway, as presumably it jsut puts wear into a slightly different part of the carden block. byut I'm not sure. RE: Short chassis prop shaft lengths? - Scarlet O'Hara - 29-04-2018 (28-04-2018, 01:57 PM)JonE Wrote: I think the consensus that it was the same as BP28... I think it's too short because the Carden blocks are sticking out the front of the housing. I'd say the prop is about 1/2 inch short to put the blocks at about the middle of the housing but when I measured it yesterday it seems to be the longer 20 inch one hence the question about the BP93. The car is fitted with 3 speed gearbox with speedo drive and Type 3 back axle but should have the Type 2 with screw in torque tube. Thanks for the advise, going to double check the length again today. RE: Short chassis prop shaft lengths? - dickie65 - 29-04-2018 Hi, I have seen a turned spacer fitted behind the carden block. I used to have one but have not seen it for years. I think I have a propshaft that has been cut and sleeved to change its length as well. Anyone with a lathe and a lump of steel or aluminium should be able the make one for you. Good Luck with your solution. RE: Short chassis prop shaft lengths? - JonE - 29-04-2018 (29-04-2018, 09:20 AM)Scarlet O\Hara Wrote: The car is fitted with 3 speed gearbox with speedo drive and Type 3 back axle but should have the Type 2 with screw in torque tube. Thanks for the advise, going to double check the length again today. Scarlet - you are in exactly the same boat as me spec wise. Email me directly - I'm still wondering whether to use the 19.5 or 20 when putting it all back together! RE: Short chassis prop shaft lengths? - Scarlet O'Hara - 30-04-2018 Thanks all, should have gone to spec savers, checked prop shaft yesterday and it's a short one. Already started on a spacer to fit behind the housing which I should have finish today. Cap screws on one side to screw spacer onto housing, studs out back to pick up flange. JonE - I'd go for the 20" shaft, I'll email you a picture of the housing / blocks when I fitted the short shaft. Once again, thanks all for comments. |
