Distributor replacement and lubrication
I have recently had my dynamo refurbished professionally and refitted it today.  When I refit the distributor, should I lubricate the drive pinion and worm on the distributor and dynamo and if so with grease or oil?  I can't find any advice on this and the lubrication charts do not mention it.
Thank you for you expertise.
Peter Venn
Th cavity surrounding the gears driving the distributor should be filled with a good lithium grease.
Thank you very much for your help David.
