Distributor replacement and lubrication - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Distributor replacement and lubrication (/showthread.php?tid=6600) |
Distributor replacement and lubrication - Venn - 04-09-2021 I have recently had my dynamo refurbished professionally and refitted it today. When I refit the distributor, should I lubricate the drive pinion and worm on the distributor and dynamo and if so with grease or oil? I can't find any advice on this and the lubrication charts do not mention it. Thank you for you expertise. Peter Venn RE: Distributor replacement and lubrication - David Stepney - 04-09-2021 Th cavity surrounding the gears driving the distributor should be filled with a good lithium grease. RE: Distributor replacement and lubrication - Venn - 05-09-2021 Thank you very much for your help David. |
