SU Carb to Ruby Inlet adaptor
Hi AN
If the RP owner had prudently retained manual ignition should have been able to find suitable timing whatever the distributor!
Although the piston probably never fully lifts I was surprised at the effect of a horiz SU on my RP; better than a Zenith bored to 19mm
