RK rear window seals...
Thank you Howard!
(07-06-2020, 02:29 PM)Ivor Hawkins Wrote: I just love that upholstery fabric in the back, I bet that’s not on Jon’s list!
Absolutely beautiful car, what a find.
Peter - do you have the build record for the car from Gaydon?
And I wonder if you have found a stamped transmission tunnel number?
The number is not on the register but it would really help to know it.
I'd be interested to know what trim was the lowest layer below the chintz and the green doorcards? It should be a cotton cloth based one... you may have all sorts of things noted in cholk scrawl behind the door cards.
