Big Seven KING PINS
How to remove core plugs from top and bottom of king pins in the easiest non damaging way to the stub axle??
I so far attacked it with a 5mm wide cold chisel which took a bit of effort and time for not much success then drilled 3.5mm holes close to each other then lowered drill gradually till virtually drilling horizontally making a slot into which a leverage could be  applied.
How do you do it?  Is there a simple quick way?
Dennis
Use a very sharp pointed drift - drive through with a sharp blow and prise out.
