Big Seven KING PINS - Printable Version
+--- Thread: Big Seven KING PINS (/showthread.php?tid=439)
Big Seven KING PINS - Dennis Nicholas - 10-11-2017
How to remove core plugs from top and bottom of king pins in the easiest non damaging way to the stub axle??
I so far attacked it with a 5mm wide cold chisel which took a bit of effort and time for not much success then drilled 3.5mm holes close to each other then lowered drill gradually till virtually drilling horizontally making a slot into which a leverage could be  applied.
How do you do it?  Is there a simple quick way?
Dennis
RE: Big Seven KING PINS - Ruairidh Dunford - 10-11-2017
Use a very sharp pointed drift - drive through with a sharp blow and prise out.
