Type 65 / Nippy Cylinder Head Gasket - Printable Version
+--- Thread: Type 65 / Nippy Cylinder Head Gasket (/showthread.php?tid=848)
Pages: 1 2 3
RE: Type 65 / Nippy Cylinder Head Gasket - Colin Wilks - 11-03-2018
(03-03-2018, 09:56 AM)Ian Williams Wrote: "I'd be interested to know what the perceived benefits are of the solid copper gasket (apart from the fact it can be reused after annealing)."
Better mechanical strength, and better heat transfer, a bugger to seal the water ways though!
Ian, I am getting one of your gaskets from Martin Baker and proposing to assemble with a smear of grease on both sides. Knowing that sealing the waterways is a bugger is interesting, but not quite so much as knowing how you resolved the issue would be. Any chance of some enlightenment?
RE: Type 65 / Nippy Cylinder Head Gasket - Ian Williams - 11-03-2018
Martin had some of the copper asbestos gaskets which are basically the same as those available in the UK but to sports pattern. I was referring to solid copper being a bugger to seal, but that said the modern C/A gaskets can be a pain too, Hylomar spray seems to be the best solution to the problem that I have used, others may have their own solution
RE: Type 65 / Nippy Cylinder Head Gasket - Tony Press - 12-03-2018
(22-02-2018, 06:54 PM)Colin Wilks Wrote: [quote pid='7350' dateline='1519319797']
I think you're right John, but I understand those for the 65 and Nippy are different to the later h/c gakets. Be interesting to know if anyone has used the 36 to 39 high compression gasket in a 1934 Type 65 without problems. I thought the intrusion of these gaskets into the combustion chamber lead to pre ignition, but I may be making that up?
[/quote]
Coming back to this comment about gasket protrusion into the combustion chamber causing pre-ignition.
It is my understanding the cylinder head temperature during running can reach a maximum of around 400 C at which temperature copper can possibly glow a dull red.
I wouldn't think this could cause pre-ignition, so a miss shaped gasket is not a major problem as long as it seals both water and combustion.
Any comments ?
Cheers, Tony.
RE: Type 65 / Nippy Cylinder Head Gasket - Colin Wilks - 12-03-2018
Film of a demonstration of ignition temperatures from 1948: https://youtu.be/yG0rP3D_0-s
Other sources quote the ignition temperature of a flammable mixture of petrol and air (1.4 to 7.6%) in a range between 230 and 280°C (https://hypertextbook.com/facts/2003/ShaniChristopher.shtml)
(12-03-2018, 10:26 AM)Colin Wilks Wrote: Film of a demonstration of ignition temperatures from 1948: https://youtu.be/yG0rP3D_0-s
With the suggested C temperatures below I would think that some other parts of the combustion chamber could 'spark' auto ignition then (or am I totally confused) ?
  1. Intake manifold : 60
  2. Intake valve : 250
  3. Spark plug : 600
  4. Exhaust valve : 650
  5. Exhaust gases : 450
  6. Piston face : 300
  7. Cylinder wall : 185
  8. Piston ring : 220
  9. Piston skirt : 190
  10. Coolant : 105
  11. Engine oil : 70
RE: Type 65 / Nippy Cylinder Head Gasket - Colin Wilks - 13-03-2018
  3. Spark plug : 600
  10. Coolant : 105
  11. Engine oil : 70
If you accept the assertion in the article's last paragraph "[color=rgba(0, 0, 0, 0.92)]The flammability range of gasoline is between 1.4 and 7.6%. If the ratio of gasoline to air is less than 1.4%, then the mixture is to thin to burn. The mixture cannot burn when it contains more than 7.6% gasoline because it is too rich to burn." then perhaps it is only when the charge has started to be compressed that it falls within the flammability range?[/color]
