Austin Seven Technical Information
Austin Seven Spare Parts List
- Factory manual number 1218B
(This list applies to chassis No.227,909 onwards - Publication date December, 1935 - 24th Edition)
Austin Seven Factory
Booklets List
Austin Seven
Choke
- one version anyway!
Austin Seven
Special - Ron Ackroyd
Ruby
Chassis (late model)
Late Sports Chassis
Drawing (6' 9" - 1933)
Murray Jamieson Twin Cam Motor
Supercharger
Information and Formulae
- Article by
Harry Pyle
Components of the Austin Badge
All British Motor House Ltd
(an advertisement from an Adelaide Newspaper dated April 4th 1928)
Austin
Seven Advertisement (an
advertisement
aimed at the female automobile buyer of the 1930's)
How do I remove the
rear spring bolts on an Australian bodied Sports Model?
Why Austin Seven Rear Springs Break?
The "Nobby" Advertisment (Anti
Bump Springs for your Austin Seven!)
Austin Seven "Nobby" spring
assistor kits - Article by Tony Eldridge
More "Nobby's"
- These original ones are used on Barry Lovelock's 1936 Tourer
Bosco's Collapsible Rubber Driver - Anti theft device
Austin Seven Spark Plugs - thanks
to David Armstrong
Austin Seven Camshaft Profiles
Austin Seven Wiring Drawing (coil engine -
positive earth models)
Austin Seven Dynamo/Generator circuits (all
models)
The New
Millennium Austin Seven (or oil leaks revisited)
Fitting an Electric Water Pump
Late Model
"D" Type Differentials - Information/Modifications
Late Model
"D" Type Differentials - Setup Information
Austin Seven
Steering Arm Modifications - Australian TQ Style
Austin Seven Damaged
Steering Box
Drag Link Rod Preload
Adjustment - modification
Holden (Australian) Body Identification Plate
Austin Seven Mechanical Starter - 1923
Clutch Release Bearing Lubrication (Late Models)
Austin Seven 19" Wheel Re-spoking (Solid
Centre Style) - by Ian Moorcraft
Artwork for Austin Seven Gauges and Instrument faces
Speedometer Summary Information Sheet
- by Ron Burchett
Austin Seven Powered
Motorcycles
Austin Seven Meteor Replica
Project - Bruce White
Austin Seven Breakdown
Spares and Tools List - Source:
The Austin
Sevens Clubs' Association Breakdown Register 1995
Austin Seven
Oil Jets
(and a simple removal tool)
Austin Seven Brake Spring Tool (a simple
home made tool)
