SU Fuel pump - mounting options
Iam looking to mount a SU pump on a 1927-8 chummy with front tank - however space under the bonnet is tight, can anyone give some suggestions on where the best place to mount the pump is?
Inside the footwell, above the passenger's feet.
Thank you
 I looked at that option lastnight, but wasnt convinced it would be easy to access should it need any maintinence.
(06-05-2025, 01:06 PM)JohnD Wrote: Thank you
You may find this article helpful; it tells you about fitting a 'transil' (in effect a capacitor) across the points to stop them arcing and so extend their life.
https://ttypes.org/extend-the-life-of-yo...a-transil/
I'm unsure if new 6-volt pumps can be ordered with one already fitted (the plastic end cap has a cylindrical bulge if they do). https://sucarb.co.uk/su-fuel-pumps-spare...-volt.html
https://sucarb.co.uk/su-fuel-pumps-spare...-kits.html
The SU website looks to have been designed by a 12-year-old on acid. Looks modern and clean, but is challenging to navigate. The menu system is hopeless, and the search is useless - put in "6-volt fuel pump" and you get almost anything but. Finally, I phoned them about a different enquiry and was given excellent help: 01722-412-500
I believe Burlen offer an "electronic" (points free) version but last time I looked I could only see a 12V model.
The standard SU pump is effectively maintenance-free if the car is regularly used.
After long periods standing idle the points can stick (in which instance a whack with a bit of wood is all the 'maintenance' mine ever needed, to jolt them free again).
I recently overhauled the pump on my Ulster rep after about 35 years in service - I only did so because I was chasing after a fault which turned out in the end to be a blocked petrol tap - so it was completely unnecessary.
